I found my Bit Char-G bodyshell so decided to have a little think of how to make a chassis for it. There seemed to me to be two ways of doing it, the second of which I completely forgot until just now which would have been to modify the Char-G chassis to a slot car one but I went with the harder other option!
I took a Matchbox Powertrack chassis which had nice big wheels to fit the large wheel arches. Took all the bits out of it and then cut it in half behind the front bulkhead.
I then did the same thing with a Turbo chassis.
I then removed the rear motor mounts on the PT chassis, cleaned up the two sections and glued the rear PT to the front of the Turbo.
It's now drying. I'm going to leave it about 24 hours to really bond and then fill any gaps in the joins with additional epoxy.
It'll then have a Turbo motor, springs, pick ups and holders and then either the PT axles if they fit (got some doubt about that) or just go with the Turbo ones.
I'll let you know how it works out but don't hold your breath because I am a lousy craftsman and if it does go together it'll probably run like a crab!
