1 - 3 of 3 Posts
I run Ninco digital with a Simple-H supply. Recently I have noted a voltage drop through the Simple-H, i.e. to maintain the 12 to 12.5 volts on the rails to ensure that the lane changers work correctly I am having to set the input supply at 14.0 volts i.e. giving a drop on 1.5 volts through the Simple-H voltage measured at the output of the Simple-H.
All connections seem to be OK. So has anyone had similar experiences?
MartinA
Digital Guru
hi
i have run a pb pro with simple h and there was always a drop in volts from what was being input.
Spoke to RichG about this and basically the diplay unit and a few other bits take the odd volt or so ,so there is nothing un usual going on..
I am not familiar with the n base does it have a display unit.???
Thanks for the info BigBird.
I just run the standard Ninco base but have not had such a problem with the lane changers and hence had never measured. How ever later I redistributed the power boosters and all seems to be working well Probably a few bad joint - and its more about current than volts.
Cheers thanks.
1 - 3 of 3 Posts
