1 - 4 of 4 Posts
· Mark R-E
Top left is the engine so under the hump behind the driver.
Next is a wing mirror and a couple of fillers either side of the hump
Two square item go above the rear wheels.
Not sure on the two silver items but the large rectangle go on the body sides in front on the rear wheels
The rear wing, bottom left, the piece above it goes in its recess. The silver piece to the left of the main wing gets folded in half around the rear body post and provides the mount for the wing.
Middle row right goes under the front of the car so you see it through the radiator vents
To its left are the exhaust pipes either side of the rear body post
Same position for the two black fences to the pipes left
I can't remember if some of those parts are from the xjr9 though
Mark
Hi Mark,
Thanks so much - you're a star!
Yes there are extra parts in the kit - such as another set of exhaust pipes and a different one-piece spoiler that fits directly to the rear post and I thought they were possibly XJR-9 too. The one-piece spoiler doesn't have large enough side plates and I'd been thinking of some way of butchering the two spoilers together but you've saved me from that!
I'm rather a newbie I'm afraid and still a bit unclear about how exactly do the exhaust fences fit, I do have some pictures of the engine bay of an XJR-12 but I'm still not sure.
And do you need heat to bend the spoiler mount without breaking it?
Thanks again
Graham
Hi Mark,
Just an update - I've fitted the rear spoiler following your instructions and it was fine no need to heat or anything to bend it, thanks again.
I'm still unsure about the exhaust fences fit though. I'd like to include these to show as much rear detail as possible.
Graham
1 - 4 of 4 Posts
