Sloting Plus new cars:
First announced at the German Toyfair in February, Reynard mono-coloured sport cars are now available where each car will be mounted with Lexan cockpit , new rubber low profil tyres in front, our M-S2 tyres in rear and a 29Z gear with the usual 11T pinion , all for improve performance out of box directly.
Parts:
Complete black ABS cockpit, white ABS driver, black inserts with brake disc integrated, screws, spacers, plastic stoppers and grub screws for front axle.
Mechanical parts are made in Spain and final assembling is hand made in Spain too. There are 4 special screws SLPL 9280 for body and rear of motor pod fixation directly on the car and the front hook is painted in red as rear lights.
References are:
- SLPL 00106 Reynard 2KQ Sport Blue
- SLPL 00107 Reynard 2KQ Sport Orange
- SLPL 00108 Reynard 2KQ Sport Yellow
About new parts:
- SLPL 2265, 2270 are simply 65 and 70 mm axle
- SLPL 1012 is Combi Plus bushing as 1010 and 1011 but with 29,9 mm length
- SLPL 1004 is a new RRSS Victor's bearing where you have blue anodized aluminium instead teflon in SLPL 1000 (shown below)
- SLPL 090102 is a complete HARD chassis for Reynard
- SLPL 090106 is white axle support more rigid if you want for SLPL 00101 decorated Reynard
Sloting Plus new system for brass and steel removable pinions where 10Z will be with Gold body, 11Z with silver, 12Z with black and 13Z with purple in order to recognize them.
References are:
SLPL 60106510 Brass removable pinion Z10 x 6,5 mm mod 0.5
SLPL 60106511 Brass removable pinion Z11 x 6,5 mm mod 0.5
SLPL 60106512 Brass removable pinion Z12 x 6,5 mm mod 0.5
SLPL 60106713 Brass removable pinion Z13 x 6,7 mm mod 0.5
SLPL 60107512 Brass removable pinion Z12 x 7,5 mm mod 0.5
SLPL 60107513 Brass removable pinion Z13 x 7,5 mm mod 0.5
SLPL 60206510 Steel removable pinion Z10 x 6,5 mm mod 0.5
SLPL 60206511 Steel removable pinion Z11 x 6,5 mm mod 0.5
SLPL 60206512 Steel removable pinion Z12 x 6,5 mm mod 0.5
SLPL 60206713 Steel removable pinion Z13 x 6,7 mm mod 0.5
SLPL 60207512 Steel removable pinion Z12 x 7,5 mm mod 0.5
SLPL 60207513 Steel removable pinion Z13 x 7,5 mm mod 0.5
Sloting Plus also propose four AW kits GT.
Each kit contains: 1 axle SLPL 2255, 1 AW gear SLPL 8030, 2 bearings SLPL 1003, 1 stopper SLPL 2400 and 2 wheels specifical to the kit.
Merkuro
Atlantis
References are:
- SLPL 48016908 Kit GT AW 30Z Merkuro 16,9 mm
- SLPL 48117208 Kit GT AW 30Z Merkuro 17,2 mm
- SLPL 48216908 Kit GT AW 30Z Atlantis 16,9 mm
- SLPL 48317509 Kit GT AW 30Z Atlantis 17,5 mm
