1 - 17 of 17 Posts
Hi Chaps,
I have not seen anyone else ask this question, so it may only bother me !!
Is it possible to change the volume of the sound samples in SSDC? I find if I set the Murray Walker ones about right, some of the others seem very very quiet. This is mainly a problem trying to hear when you need to refuel.
Any thoughts?
Thanks, Martin
Andrew Wallace
Mr. F - I have just updated the finish horn so that it is optional. Must have overlooked that when I did the move of code from v4 to v5. I will also check the various sound files and make sure that they are at similar volume levels. Should be easy to do. The hard part is matching speech and audio volumes. I haven't worked out how to do that yet.
The wav files have always been louder than the speech for me, but when I asked about that a long time ago I think you said there wasn't a way you could provide to adjust one but not the other. I've gotten used to that. Thanks for putting the horn option back in. I much prefer the ding sound that comes in the Windows media files for that.
Nothing special for me. I usually set the "normal lap" to a simple blip sound so that I know a lap was detected, but it's not an annoying sound. I also change the race end to a ding for the same reason. The others depend on my mood, but I usually go for the voice/speech whenever possible.
Hi Chaps,
Thanks very much for the replys, sorry I am late answering I have been buisy working late.
I usually run with the speech calling out the driver's name ie "Martin you are running out of fuel" but the start sample of Murray Walker is much louder so it was difficult to hear your name called, when set at a comfortable level for Mr Walker.
To try to overcome this is to put in the name as "Martin Martin Martin" then it says " Martin Martin Martin you are running out of fuel" which is more noticable in the heat of battle !
I have recorded my own sounds as well, and I use these. For example I have recorded my own "Fastest Lap" one, as I found the original was too long. I was wondering if it is possible to add a volume control to each sample for the user to change ( values 1 to 10 possibly) like you can in some computer games. Then the user could set what they would like.
Thanks Andy very much for trying to balance the relative volumes, I hope to have play at the weekend.
If anyone is interested in making thier own samples, I used Audacity which is free recording studio software.
Cheers Martin
Discussion Starter · #14 ·
Hi Andy,
You said you have reduced the WAV files by 6dB. To take advantage of this modification, do I just re download the latest version from the SSDC website ?
Thanks again for all your help.
Cheers Martin
Hi Skot,
And anyone else interested, I recorded my son saying "Fastest Lap" onto the computer, and saved it in music as a .wav file.
Then I opened SSDC and pressed Tools, then Options, then Sounds. Then chose Custom and located the file.
I hope this helps.
Cheers Martin
Andrew Wallace
QUOTE (slotmartin @ 16 Jun 2011, 17:09) <{POST_SNAPBACK}>Hi Andy,
Cheers Martin
Hi Martin - I haven't uploaded the changes yet to the SSDC site. I am working on support for wireless throttles and improved braking at the moment, so the sound mods will get included in that release. Should have something posted next week some time.
1 - 17 of 17 Posts
