1 - 1 of 1 Posts
I recently purchased 2, 2004 V8 supercars and converted them to digital using the porsche boxsters chips as donar digital chips. One of the two worked well, however the second converted was much more sluggish than the 1st and could not match its speed and had trouble taking off from a stationary start from certain parts of the track, that the other had no troubles with. Intially thought might of been a dud motor in it so swapped motor in both cars and the problem still remained despite a proven motor. Also checked factory solder joints and found insultation soldered into the guide blade contacts, corrected this and still its was a failure. Any Ideas why this could still be happening?
Thanks.
1 - 1 of 1 Posts
