241 - 259 of 259 Posts
*** Leo A Capaldi ***
Really fabulous layout Randy, great overall vision an great details.
Not seen Steve yet !
Leo
earing up scenery to do a "remodel". OK. I need a place to plant my 2 new buildings. I designed them to fit in one particular spot, I did so, however, after I had already finished the scenery in that section. No worries, that's what a utility knife & putty knife are for.
I wanted to plant these 2 buildings to the left of the large tan building in this first photo. To do so though, I'd need to get rid of the sculptamold and grass in that section.
I carefully measured, cut the edges with the utility knife, and then pried out the grass section with the putty knife. It came out in one clean piece, because I do all of my scenery sections on sheets of cardboard.
I cleaned up the mess with shop vac....
And then plunked the 2 new facades in place. They are held in place by 2 small drywall screws so that they can be removed for maintenance and cleaning.
I still need to add straw bales/figures etc but you get the gist of how the new facades look.
Lovely buildings! And they look practical as they are slim, so I guess they dont use to much space.
Discussion Starter · #253 ·
I made a Coca Cola billboard for the circuit. While they did have some of the "classic" Coke logo billboards, in 1970 this more plain version was also seen at the track. I used styrene to create it, spray painted it white, and then aged it a bit using flat tan & primer gray. These are both just sitting here loose yet, I need to trim the bottoms to fit the terrain & glue them in place.
My favourite coca cola ad at Le Mans is from 1969,on the inside of the track just after the signalling pits at Mulsanne.
Illustration of a classic coke bottle at about 60 degrees, with the strap line Coca Cola deseltre le mieux, so period France.
Discussion Starter · #257 ·
Hi David. Thanks for asking. Not much new, in fact, the layout is covered with a plastic tarp for the moment, as I have just been too busy w/work to play with it. That said, it's still pristine & is awaiting my return soon! :)
Randy
