Completely new to slot cars and table design and construction and materials recommended. This track will be setup and left setup as permanent, as for scenery well I thought so but for now I want to concentrate on the track and the table.
Trying to work out what timber and materials I should use to construct the table. MDF or Ply? Thickness?
I have uploaded some images of the Ply which I think would be better than MDF as it doesn't fall apart. Just unsure about the thickness of the base board, e.g. 9mm, 12mm, 19mm etc.
Not all ply is the same, as you can see in the images provided there is one that has large knots which I don't think will be sufficient for use, I could be wrong on this though.
I also am looking at the saw horse/s to mount the table on. Hopefully someone can provide me some direction with this.
Johnno
P.S. A quick check on Bunnings.com.au for these items locates the following (included are the url's for the items):
Project Panel 900 x 600 x 9mm Premium Grade Radiata Plywood
https://www.bunnings.com.au/project-panel-1200-x-900-x-7mm-premium-grade-radiata-plywood_p0390147
Project Panel 1200 x 600 x 9mm Premium Grade Radiata Plywood
https://www.bunnings.com.au/project-panel-900-x-600-x-9mm-premium-grade-radiata-plywood_p0390148
Project Panel 1200 x 900 x 7mm Premium Grade Radiata Plywood
https://www.bunnings.com.au/project-panel-1200-x-600-x-9mm-premium-grade-radiata-plywood_p0390149
And the sawhorse to sit the table on:
Craftright Folding Bench n' Vice
https://www.bunnings.com.au/craftright-folding-bench-n-vice_p5860871
Craftright Folding Metal Leg Saw Horse
https://www.bunnings.com.au/craftright-folding-metal-leg-saw-horse_p5710162
Craftright Folding Saw Horse - 2 Pack
https://www.bunnings.com.au/craftright-folding-saw-horse-2-pack_p5828526
Johnno
