VBs are always welcome
. I don't mind the shameless invites, would be great if you guys came around
(I hope all in our household agree
). I've got no idea when the "opening" will be, but if I had it my way I'd be there building on it night and day... unfortunately there are those other things to do too. I'm hoping to get a couple of days in this coming weekend. And to then get done with the fiddly bits of getting the remaining three sheets clamped down and getting the two halves fitting perfectly together. Then there is the routing which will take a fair while with all those different radii... I've managed to finally find a 3mm router bit (8mm shank) from a place (Maskinboden.se) locally. Next thing to buy is coppertape, does anyone know a good and cheap place for this. I heard that Pendle sells it, but I didn't find it on their site. Last time I used tape bought from a lead light window shop in Melbourne. That worked well and was about 5mm wide, and it had good adhesive but I have no idea what brand it was so it doesn't help me now. Are there any brands to be avoided, or do I just get the first thing that I find here? I take it most of them come in about 30m rolls, so I'll need about three of those.
For all of you guys out there hesitating to give trackbuilding a go, just do it! It's not at all that difficult and it's great fun building and you learn a lot as you go along and you get great pleasure seeing the track take shape, and best of all is that there are no limits to what you can build, any radii, any degree turn, any banking, any number of lanes, any lane spacing, so all in all you're the master of the design. Another benefit is that it'll probably become cheaper than buying plastic track too
. In my case I couldn't have squeesed as much track and lap length in the given area using plastic either, and another benefit is that you won't even have to remove the magnets from your new cars
and it's so smooooth to drive on wood too. As you see I could go on and on, but I think you get the picture, so if you're thinking of it, just do it
