Temporary Adhesives
511 Views 13 Replies 8 Participants Last post by  ridgeracer
Seems I always find the cars with wobbly guide pins/bodies. Does anyone have a tip or know of a product to secure such things without making it permanent? I have some Blu-Tack, says it's safe on plastic. Might see if that holds a body secure. Stumped on the pins.
1 - 14 of 14 Posts
Maybe you could try white glue (carpenter's glue) as doesn't stick so well to plastic and can be removed later, but would be enough to secure the guide pin in place.
  • Like
Reactions: 1
For the bodies, what kind of bodies are you talking about?
Look for "E6000" adhesive,...available in the US at Home Depot, Lowes etc.
It is an Industrial strength semi flexible adhesive that is great for plastics/metal/rubber,....it is high strength, can be removed fairly easily, and is resistant to water and most chemicals............perfect for what you are describing,............a go to adhesive for many folks in our hobby.
Chris Walker
  • Like
Reactions: 2
I have a couple of magnatration 512's that are super loose on the chassis. One's lighted and one's not. The lighted one is the loosest.
One thing to try would be contact cement. Life-Like cars used to come with their bodies stuck on with contact cement, otherwise they would come off if the cars crashed.
  • Haha
Reactions: 1
Thin double sided tape on the tabs could help.
  • Like
Reactions: 1
UV glue. It holds well and is easy to chip off if needed. (Pick up the type with the small application tip.)
  • Like
Reactions: 1
This seemed to do the trick. Like a piece of bubble gum, just not as messy!
Automotive design Wood Material property Nail Automotive lighting
  • Like
Reactions: 1
Well, that did not work out in testing. It ran like a dog wagging it's tail. Perhaps much less, with equal weighted amounts on both sides.
I'd be concerned about any goober getting hoovered into the armature.
Have those mounting tabs been shaved down? I have a few of those and they are all tighter fitting than most of my A/FX. My Chevelle Stock cars are very loose. I just put a small rectangle of blue painters tape over the mounts before inserting the chassis. Still loose but enough to do the trick.
Google 'Glue dots'. We used them at our HO club to hold bodies on in the event of a crash - and they did! but still allow easy removal for servicing, etc.
  • Like
  • Helpful
Reactions: 2
It came off no fuss, no muss which is nice, I've snapped the sides off of a couple of these brittle old things. Second attempt a little better. I was mistaken, it's a non magna chassis, maybe that's why the poor fit? Anyway I think the glue dots sound like a lighter and less sloppy solution.
Automotive lighting Motor vehicle Vehicle Automotive design Nail
Wheel Tire Vehicle Motor vehicle Automotive tire
1 - 14 of 14 Posts
