Hi great video yes the TFX are great chassis i got mine when they first came out. just need a slight higher rear tires . chassis drag on track but all other items are great on it. what ohm armatures did you order on yours . there full line of parts are great. do you also race the vintage aurora t/jets yet. i am new to slot forum .
16ohm armature. We're just setting up a Viper track and yes I am also racing TJETS.
Hi on the car you are showing are you running gears on the gear plate or is that the new/old belt drive that is back again now. car looks like a good runner /racer. track also looks great to run on. great job on everything you are doing.TFX cars come with silicone tires and those work best on a perfectly clean track. The TFX tires have better grip after they have been scuffed in. I run some of my TFX cars with the stock tires and some with Pro Series Super Tires on CNC machined wheels.
Hi when i answered him on that about ohms on armatures i was just in general saying lower ohms armatures need a good power source to run them. and do run hotter. a lower ohms armatures do run cooler . but yes any armatures need the right set up. to run there very best. that would be any motor. if i may ask on the 2ohm armatures how long can he run and how many laps before a cool down was needed. 2ohm drag racing only. your 8.4 ohm armature is very road race able. but will need a cool down on a very long race. and yes every build is going to need the right set up to live a long race. that is what is great about slot are racing teaches you a lot on many things.I don't think that OS3 offers a TFX belt drive option. RT-HO sells the pulleys and belts to convert pancake cars to belt drive. SouthShoreRacing started a thread about the conversion a year ago. I was tempted to evaluate a car with belt drive, but it would not have been legal for formal racing.
For people having track clearance problems with TFX cars several larger diameter front and rear tire sizes are now available. If you were using a body with the screw posts cut for a regular T-Jet type chassis you would need at add a front spacer when you put that body on a TFX chassis. I find that guide pin bases are the right thickness.
Using an armature with a lower ohm rating does not always result in a car with better performance. An armature with a lower ohm rating will pull more amps. The amount of power that the armature will generate will depend on a number of factors, including the ohm rating, the number of windings and the strength of the motor magnets. For a start, if you use thicker wire to lower the ohm value the number of turns would be reduced. Another thing to consider is that while an armature has an ohm value it should not be considered to be a resistor unless the armature is not turning. An armature that is turning becomes a generator and the voltage that it will produce opposes the applied voltage, that back EMF will cancel part of the applied voltage. That is why a motor that is operating properly will draw a nearly constant amount of amps over a wide range of applied voltages. If the motor magnets are stronger the amount of back EMF will be higher. Magnets need to be matched to the armature, if you go to a lower ohm value armature you would be more likely to benefit from using stronger magnets.
Lower ohm armatures do not necessarily run much hotter. I am racing a T-Jet with a 8.4 ohm armature and that does not get hot. A fellow racer has a 2 ohm armature in one of his cars with no heating problems. There are several more reasons that a motor might heat up, you could be using the wrong oil, the gears might need lapping or the motor magnets might be too weak.
Hi when i was talking about the armatures before i should had said only new ones or a good one with the right ohm reading on each pole .being checked with a good ohm meter. then you can do the build for that motor. pancake motors run way different than inline armatures. take a 8.4 pancake and a 8.4 inline . the inline will always win. so i am talking about pancake motors when talking about ohms and heat and rewinds and dewinds on them only.I don't think that OS3 offers a TFX belt drive option. RT-HO sells the pulleys and belts to convert pancake cars to belt drive. SouthShoreRacing started a thread about the conversion a year ago. I was tempted to evaluate a car with belt drive, but it would not have been legal for formal racing.
