1 - 17 of 17 Posts
Al Schwartz
Or at least as far as Utah - If it "flies" on the track is to be seen.
Some may recall that I added a coda to my "Hatching an Eagle" thread last spring describing the unfortunate practice incident wherein an errant flying doorstop carried the Eagle into the wall at an horrific speed with the resultant loss of 3 of the 4 tailpipes and the drivers head. I subsequently determined the the front axle carrier had been slightly bent causing an intermittent bind.
One of the less endearing characterisitics of polyester resins is their brittle nature. When I examined the remnants to see if rebuilding was possible, it was clear that so much of the exhaust manifold detail had been carried away with the pipes that the shell was , at least for me, a total loss.
A replacement was ordered and arrived in good time. I decided to avoid the possibility of a repeat of the previous experience by re-creating the body in a less frangible material. I will briefly describel a process that I have used for some time will good results.
The shell was cleaned up, a few minor surface imperfections filled and smoothed and a little modification done to increase the space in the rear by about 0.5 mm in each direction. This shell was converted to a pattern by stuffing it with modellling clay and a silicone rubber mold was poured.
With this mold in the rigid carrier in which it was cast I slosh cast a very thin resin shell using a slow curing (20 min pot life) high strength resin. This was allowed to cure for about 48 hours and then,without removing the shell from the mold strategic reinforcment was done by laminating very thin kevlar scrim to the inside of the shell using a low viscosity epoxy resin. After another 48 hours, the resultant body was removed, cleaned up and prepped in the usual fashion.
This body weighed 3 grams compared to the 7.5 gram weight of the bare fibreglass version.
The chassis is mostly unchanged except that I used this opportunity to remedy a defect in the original model. I felt that the first one had a bit of a "nose high" attiitude. I scrapped the front end assembly (providentially held on with 2-56 machine screws) and built a new one, unashamedly copying David Lawson's " full width upper suspension member" practice. This is the result with the original version in the foreground:
Careful examination will reveal a layer of black material between the assembly and the chassis. This material is, in fact, 0.050" rubber which, combined with the machine screw fixing, allows one to adjust the height of the front end over about a 0.012" range to accomdate different braid or rail height or recess.
Next I turned my attention to the rear and did a bit of judicious filing of the rear axle carrier and skimmed about 0.008" from the periphery of the gear so:
(Sorry about the focus)
This and the minor mods to the rear of the pattern resulted in much less mayhem perpetrated on the rear of the shell.
And it all went together like this:
And, particularly for Russell:
I also changed tires and added about 3 grams of lead under the motor - We shall see
On to the next project!
EM
The reborn Eagle looks very nice EM, the bodyshell sounds like a Kevlar Exorcet which will cut my poor BRM in half if they get together in the Proxy races.
Al Schwartz
QUOTE (jhardy33 @ 3 Nov 2004, 15:43)EM,
Looks outstanding! Maybe I missed this in the earlier post but could post a few more photos of the chassis? Very nice work. Is the motor bracket available for purchase and if so where?
Jay
<{POST_SNAPBACK}>
Thanks (to you and my other friends on the forum) for the kind comments.
I think you will find the original photos here:
http://www.slotforum.com/forums/index.php?showtopic=2235&hl=
The bracket is a home-brew job done on a small mill from a chunk of brass. I am currently looking into the possibility of having a small run of brackets for this motor done in stamped steel. The economics don't look too bad. I like working in steel because of its strength and the fact that you can solder to one part without all the previously attached bits falling off! The downside is that steel will corrode but it may be possible to have the brackets nickel plated without too much additional cost.
I'll keep the forum informed of progress.
EM
Brian Ferguson
EM, fantastic work! That is a truly superb repro-restoration job!
Everything looks great, glad the Eagle has risen from the ashes.... wait, that was a Phoenix... never mind, he's a different guy here!
I love to see stuff like that custom bracket.... makes me want to play with metal again!
QUOTE (Ken R @ 3 Nov 2004, 16:39)Can you let us know whose body that is and where might one be sourced?
Many thanks, Ken R
<{POST_SNAPBACK}>
If EM doesn't mind me answering on his behalf, the original body before EM's complete re-working is by Betta and it's available from http://www.abslotsport.com/
Al Schwartz
Discussion Starter · #14 ·
Thanks, David - I had it in the back of my mind somewhere - but - after all, memory is the second thing to go!
And - thank you for showing the way on the front end assembly - your method is a hell of a lot easier and more accurate than the bent up sheet system I used on the first try.
EM
Sorry Ken. Even after 40 years of buying the Classic and Betta bodyshells I still get mixed up, must be the Alzheimer's....the Eagle is from the Classic fibreglass range - the Betta range are vacforms both of course made by Mr Fitzpatrick. The website details I gave are correct.
Now I've just got to remember my own name..Erm
Oh yes, David
1 - 17 of 17 Posts
