Thunderslot Can Am Challenge 2020 Nascot Wood May 10th 2020
2511 Views 18 Replies 6 Participants Last post by  abbo
During the early part of next year, there will be three chances to qualify for the Thunderslot UK Championship, with the final being held at the UK Slot Car Festival in May 2020.
It has just been confirmed by GaugeMaster that the following dates and venues will allow you to try your hand at becoming the UK Thunderslot Champion.
Rules and Regs are virtually set in stone and I believe that at each event the top three drivers will also receive prizes of some kind.
The event(s) will be managed by Gaugemaster and Thundersolt and I'm sure that Terry will have more details soon.
Therefore, can we use this thread to keep things all in the same place and any questions will be answered ASAP by those in charge of the event and/or club.
Wales and West 19th JAN - Red Dragon - Llantrisant Slot Car Club
Northern 29th MARCH - Pendleslot Raceway - Nelson
Southern 10th MAY - Nascot Wood - Watford
ABBO
  • Like
Reactions: 4
1 - 19 of 19 Posts
Aw, c'mon. Don't tease us.
Font Recreation Grass Magenta Electric blue
Can I have some, please?
Great poster too, but before it spreads too far, you may want to add the missing apostrophe! Apologies for the pedantry, but I'm sure I'm not the only one to notice it.
I was thinking about the apostrophe and it unbalanced it... but I'll change it, that way you won't have the usual nightmares.
Marc
Lol. My car failed the NSR Classic scrutineering for being 0.06g underweight, which is probably less than an apostrophe weighs, so I'm used to the nightmares!
Looks like it will be a great event though, so hopefully I'll be free on that weekend.
Ric's going through all the rules at the moment as the original was in Italian... and then Google-translated (I think) to English. They are quite easy and nothing strange, but... just in case
Marc
Lets go out to eat grandma
Let's go out to eat, grandma.
OK - here's the regulations sent by Giovanni. They are fairly simple and basically you can only use Thunderslot parts.
I am still waiting for absolute confirmation from Terry at Gaugemaster as to how many drivers can qualify for the final - He initially told me that simply entering one round will allow you to race at Gaydon, which I personally think is a good idea, and I don't see why this will change.
At Nascot Wood we will do 6 heats for each driver, but best 5 to count. These will then place you in finals - so in theory if you qualify last, you have an outside chance of working your way up to the top and winning. Obviously other clubs might have their own system.
I have also been told that there will be good prizes for 1st, 2nd 3rd at each round.
TECHNICAL RULES FOR THE THUNDERSLOT
CANAM CHALLENGE 2019 - 2020
The technical rules applied here are based on stock box cars with some modifications as listed below.
It is permissible to race both versions of the Thunderslot Lola - the T70 MKIII Coupé and T70 Spyder - as well as the McLaren M6A/B and the new model McLaren-Elva
The improvements are allowed as follows:
1) Front tyres can be replaced with the Thunderslot spare part code TYR003FR.
2) The stock rear rims RMR001AL (dia14.3mm.) can be replaced with the Thunderslot spare part code RMR002AL (dia14.85mm.).
3) The sponge rings Thunderslot spare code RMRFM001 can be fitted to the wheel rims.
4) It is permissible to use other makes' axles, as long as they are not hollowed or machined down.
5) Gluing the standard bronze axle bearings to the motor mount is allowed.
6) Braids and motor wires are free, but standard Thunderslot guide must be used.
7) It is permissible to replace the original white 32-tooth gear with the spare parts Blue 31T GE31SWP or the Orange 30T GE30SWP.
8) It is permissible to replace the stock black motor mount with the Thunderslot spares codes MTS001G (grey) or MTS001S (dark grey).
9) It is permissible to replace each one of the four standard black chassis in accordance with the following list :
Lola T70 MKIII Coupé - grey CHS001G and dark grey CHS001S
Lola T70 Spyder - grey CHS002G and dark grey CHS002S
McLaren M6A/B - grey CHS003G and dark grey CHS003S
McLaren-Elva - grey CHS004G and dark grey CHS004S
10) The adding of Allen screws, spares code SC2.5HEX, on the chassis' four lateral holes to set the body on the chassis itself is allowed.
11) Rear view mirrors can be missing.
12) On the Lola Spyder, you may install washers between the front screw posts and the chassis pods to a maximum thickness of 1.5 mm.
13) On the Lola Spyder, it is permissible to remove the dummy gearbox and replace it with a washer of 1.0mm thickness.
14) The racing tyres TYR004R will be supplied by the organisers and must be fitted prior to the car entering Parc Fermé. Any kind of liquid / goop is strictly forbidden at all times! Tyres may not be reduced in overall diameter prior to the start of the racing, though it is permissible to remove any moulding discrepancies or flashing.
15) Motors - The only motor allowed is the standard Thunderslot 21.5K Ref: TSLMTMACH21 using the 11 tooth pinion ref: PN11PL
16) All motors must be fitted with the Thunderslot 11 tooth pinion. They will be checked for revs and magnetic field before entering Parc Fermé.
17) In the case of a self-painted bodyshell, fluorescent paint is not allowed. Period colour schemes are encouraged and cars must carry a minimum of three racing numbers.
18) The wheel inserts must be installed.
19) The minimum body weight for the Lola T70 Coupé is 17g whilst for the Lola T70 Spyder it is 13g.
20) Maximum width across the rear wheels is 61mm.
21) Adding weight is allowed, but it must be securely fixed to the chassis area (inside the car) and be invisible from the outside.
22) The fitting of a Thunderslot suspension kit is permitted - Ref: TSLSUSK003.
  • Like
Reactions: 1
Driver entries (so far) for Nascot Wood:
The cost per driver is £10.00 payable in advance (non refundable).
Graham Eldridge
Mark Long
Martin Dixson
Nic Child
Nicholas Child
Marc Abbott
Neil Thompson
Alan Wilkinson
Paul Hearne
Russell Turner
Steve Mitchell
Darren Tidmarsh
Ray Brownson
Yusuf Syed
Maurice Eldridge
Preston Eldridge
Gary Long
Martin Brownson
Paul Bizzell
Gary Cannell
Dave Druce
Andy Player
Giovanni Montiglio
Entries at Nascot Wood update...
Graham Eldridge
Mark Long
Martin Dixson
Nic Child
Nicholas Child
Marc Abbott
Neil Thompson
Alan Wilkinson
Paul Hearne
Russell Turner
Steve Mitchell
Darren Tidmarsh
Ray Brownson
Yusuf Syed
Maurice Eldridge
Preston Eldridge
Gary Long
Martin Brownson
Paul Bizzell
Gary Cannell
Dave Druce
Andy Player
Arif Syed
Giovanni Montiglio
  • Like
Reactions: 1
Quite rude to start collating names for the third round of a championship in 6 months time but not bother taking names for the first round when creating a thread introducing the series?
  • Like
Reactions: 1
hmmmm - I have no power over other clubs and it is up to them to post who will be entering. I started this thread as "catch all" for the clubs involved, however, Red Dragon has started their own thread and are collating names/entires on that.
There will be a maximum number of entrants each club can cope with (I assume). Already I have listed people from 4 clubs entering at Nascot Wood... people want to make sure they reserve a place and don't get left out.
  • Like
Reactions: 1
I presume they are 3 separate independent events and not 3 rounds, even if your poster states that. If they are rounds Lee has a valid point
What result will gain a qualification to the Gaydon final?
What track will the Gaydon final be run on?
Matt
As I understand it, you only need to enter one round. The info coming across has been patchy to say the least and I'm only going on what I've learned so far. Originally, I was of the impression that they were going to be "rounds", but I am now led to believe (and it makes more sense) that you only have to enter one.
I'm now also getting conflicting info on how you actually qualify... it has been stated that all you need to do is turn up to one event and you get a place in the final and yet I have also heard that it would only be a certain number from each event.
It'll be very easy for me to change the word "round" and just use the poster to advertise the Nascot Wood event and leave the other clubs to do their thing if it has created the wrong impression.
However, I think the organisers need to take the lead and state exactly what's going to happen (Gaugemaster).
  • Like
Reactions: 1
Looking forward to this - sounds a blast. And it's a very nice upgrade to Giovanni's traditional eve-of-Gaydon Thunderslot thrash at Nascot Wood.
Thanks for sharing Marc - it would have been rude to keep it under your hat. Twenty-four on the grid already is fabulous. Hopefully we can add a few more from Worthing.
I'm guessing those interested in the other two rounds/events/qualifiers could contact the clubs involved to register their interest
I'll await the qualifying criteria for the grand final in due course - it is nearly six months away...
  • Like
Reactions: 1
Hi Guys,
I just thought I would give you all an insight to the above series. Gaugemaster came up the idea of holding regional events with a final at Gaydon some months ago and we needed to get the ball rolling as we know how quickly the race calendar builds up. We wanted to get everything in place before we mentioned anything to Giovanni. Pendleslot were first to commit and while the Wales and West guys had confirmed they would hold an event, they took a bit of time in finding a suitable date. I also approached another couple of clubs who initially seemed keen but eventually declined. Unbeknown to me Nascot Wood had started to arrange their own Thunderslot Can Am event in May and as this was well underway we decided it made sense to include their race, with their agreement, into the series.
Nascot were already talking to Giovanni about the rules, which seemed pretty open, whereas I had wanted the series to be based on box-stock cars. After consultation with Jo we decided that we would now adopt everything he put forward, and also allow full suspension and chassis ballast, the latter he was initially against. These rules have been available on this site for a few days now. As for the series being rounds, heats or whatever, to keep things simple you must race at a regional event to qualify for the Finals at the UK Slot Car Festival in Gaydon and that's it. There might have to a limit possibly 32 as it will be held on a 4-lane Ninco track build hopefully on the Friday evening with the race itself on the Saturday. As the track pieces will be supplied by both Gaugemaster and Red Dragon (Wales and West) I believe they may be holding their own race on the track on the Sunday, but please contact them directly. If you want to show your interest in attending any of the regional events then please also contact the host club directly.
There will be control tyres handed out at each event plus motors at the final. The regional events will have prizes and at the final there will be more special prizes and trophies for the podium spots and we are looking at possibly adding something a bit special, so watch this space. There will be no charge at Gaydon as you will have to pay to get in, however the regional events will have a small fee for race entry.
In the event that we do get more than 32 racers at the final then we have a system in place that will make it fair to everyone, but let's not worry about that just yet. Happy racing!
Terry
  • Like
Reactions: 1
Confirmed entries so far...
Graham Eldridge
Mark Long - PAID
Martin Dixson - PAID
Nic Child
Nicholas Child
Marc Abbott - PAID
Alan Wilkinson - PAID
Russell Turner - PAID
Ray Brownson - PAID
Yusuf Syed - PAID
Maurice Eldridge
Preston Eldridge
Gary Long
Martin Brownson - PAID
Paul Bizzell - PAID
Gary Cannell - PAID
Dave Druce
Andy Player
Arif Syed - PAID
Ed Pink - PAID
Martin Cannell - PAID
Andy Player
1 - 19 of 19 Posts
