Some of you will know that I have started on a BIG rallytrack and part of my 'old' smaller rallytrack will be built into the new one.
I wanted to try a few ideas before I start on the big one and I wanted a track that would fit in the play den for 'off stage' practice. I thought if I am going to do a small track then I might as well do one that will fit into the back of my Astra Van. My van is the one that looks like an estate with no windows so it's not huge so this would probably go into most hatchbacks with the rear seats down.
The table size is 44" x 65" - I did tell you it was small
It's laid out on the floor of my workshop and the camera is on charge so I should have some pictures later. Obviously I need to cut a few sections and make one custom squeeze section so I will need to take a look at how Zipp did that
Here is the track plan ...
Only one lane changer so obviously one lap is both lanes if that makes sense - Lap length is amazingly about 13.5 metres.
It will be wired with brakes and be able to run in both directions.
