1 - 9 of 9 Posts
Hi ALL,
This may sound a slightly strange question but does anyone know of any pc programs to assist in track layouts?
I:E can I input how many pieces of straight and corners I have then get suggested layouts?
Many thanks Mike
Nothing that generates ideas for you, but there are several that you can 'tell' what you have in terms of track and it reduces the amounts as you build layouts on screen.
The key thing to do whatever method you use is to avoid constant radius turns that only go one direction - Tomy gives you 10 curve options every time you lay a piece, so why not use them? - and mix some diagonal stuff in with the left-to-right & top-to-bottom stuff.
Ultimate Racer has a track design section which it is relatively simple to use and you can generate your own track pieces.
1 - 9 of 9 Posts
