1 - 20 of 103 Posts
Several people have hinted that they want to know how to make aluminum chassis from 3/4 inch aluminum square tubing. My apologies in advance for the size of this thread. This is simply how I make them. I take no responsibility for anyone doing their own thing. Always keep safety in mind before performing any machine work (safety glasses, etc...).
I bought this Airfix static model for five dollars at a flea market last year.
Tire Wheel Land vehicle Car Vehicle
The paint is now two weeks old and safe to handle.
Automotive design Bumper Automotive exterior Rectangle Gas
The first step is to measure the body. Choose a motor and gears. True the tires to fit the car. Figure out where the guide and body posts and axles should go, etc...
Rectangle Vehicle Material property Parallel Font
A local hardware store supplies the 3/4 inch square aluminum tubing (Home Depot). It measures 3/4 x 3/4 x 1/16 thick. Hiding somewhere in this material is a Triumph chassis. It's been marked and scribed for hole location.
Rectangle Wood Gas Aluminium Auto part
A good drill press, with a precision vise, on a compound table (precise XY axis movement absolutely required). Best speed is slow (600 rpm).
Wheel Tire Automotive tire Automotive design Wood
I drill the body posts first. Tools required. 90 degree countersink. 0.121 inch clearance drill for a 4-40 screw. Number 2 pilot drill.
Wood Household hardware Font Metal Tints and shades
A good machinist always uses a pilot drill first for a properly centered hole. It can also be used as a locator for pin point accuracy on the cross hairs. You can make a small dot and see how accurate you really are. If you are off a little off, you can make a correction and the drill bit won't wander because of the large shank. Plunge the pilot when it's spot on. No oil required for the pilot drill through aluminum.
Wood Rectangle Eyewear Gadget Automotive design
Wood Machine tool Machine Kitchen appliance Tool
Small dot to test the accuracy.
Rectangle Wood Granny smith Box Communication Device
Looks good. Plunge the pilot drill through the material. Then without moving the part, table or vise. Change to the 0.121 inch drill bit, use a drop of oil, and drill through.
Eyewear Gadget Rectangle Silver Audio equipment
Gadget Communication Device Wood Audio equipment Gas
Without disturbing the part. Change to the 90 degree countersink and start the process. I test fit the screw to make sure it sits just below the surface.
Wood Gas Audio equipment Machine tool Hardwood
Gadget Gas Automotive design Communication Device Metal
The XY compound table lets me move the part without removing it from the vice keeping the part square at all times. Repeat for the other body post hole.
The guide is next. Tools required. Number 27 drill bit. Number 2 pilot drill.
Same exact instructions to drill this hole but no countersink. Pilot drill first (dry). Drop of oil. Then number 27 drill bit after (for Slot It guides). When you have just the right pressure on the drill bit. The material comes out in two large twisted strings.
Gas Rectangle Auto part Automotive exterior Metal
More to come...
KRZ
Most informative. Thanks. Been thinking for a while that a length-adjustable version of your chassis could be marketable.
Alternatively, non-adjustable units built to order. I'm thinking aloud, of course.
Now that the guide and body posts holes are done. We need to flip the part 90 degrees in the vice and locate the cross-hairs for the bearings with the pilot drill.
Tools required. Number 2 pilot drill. Number 14 drill, and a 3/16 inch reamer.
Wood Office supplies Font Metal Natural material
Tool Office supplies Hand tool Wood Metalworking hand tool
Pilot drill completed. That sets up the accuracy to drill straight through both sides of the aluminum tubing. The larger number 14 drill brings the hole to within .005 thousands of an inch to the required size. A reamer can't drill a hole. Only finish it off... very accurately. Remember not to move the part while going through the steps. Don't forget a drop of oil before every machining process except for the pilot drill.
Wood Bumper Machine tool Gas Automotive exterior
You can see a bit of aluminum hair left on the reamer. That's all the material it needed to remove to make it a perfect bearing fit.
Liquid Drinkware Fluid Barware Gas
The compound table is now move over and adjusted to do the other bearing saddle. Same steps again. Pilot drill. Drop of oil. Number 14 drill. Another drop of oil. Then the reamer. Now you end up with a square piece of tubing with lots of precision holes.
Circuit component Font Electronic component Fashion accessory Electronics accessory
The bearing saddles are marked with a special jig (aka popsicle stick). Then a line is drawn across the bottom to help avoid damaging the material while cutting.
Rectangle Office supplies Font Tool Wood
Then the bandsaw fun begins. Everything free-hand.
Wood Audio equipment Gadget Flooring Hardwood
Wood Flooring Rectangle Hardwood Bumper
Wood Fluid Floor Wall Material property
Wood Flooring Floor Gas Tints and shades
Wood Automotive exterior Bumper Gas Rectangle
Automotive lighting Bumper Office equipment Gas Automotive exterior
Now we have a roughed out chassis.
Wood Rectangle Tool Screw Metal
More to come...
The guide hole needs a line scribed about 1.65mm from the edge to help prevent going too far with the file.
Wood Auto part Fashion accessory Metal Hardwood
The rear body post needs a line marked so it also doesn't get filed too far.
Brown Tableware Furniture Drinkware Dishware
Bandsaw rough cut.
Wood Household hardware Gas Rectangle Metal
The bandsaw was very carefully used to remove rough material around the guide.
Wood Font Metal Cylinder Nickel
A disk sander finished off the rear of the chassis to a super smooth finish.
Door Wood Automotive exterior Tints and shades Wood stain
A hand file finished off the guide area. It's ready for assembly.
Metal Nickel Titanium Steel Fashion accessory
Wood Rectangle Aluminium Automotive exterior Metal
Wood Household hardware Rectangle Font Jewellery
Automotive exterior Bumper Everyday carry Auto part Wood
Thank you very kindly for looking.
Bumper Automotive exterior Rectangle Automotive design Auto part
Here's about half of the scrap from the other chassis's I've previously built.
I used to throw it away when I first started down this path.
Wood Rectangle Triangle Art Aluminium
Kindly let me know if anyone has questions?
Ken
A small slot may need to be added for the crown gear. I'll only know after test-assembly.
My apologies for any mistakes or typos. It's almost 4AM here.
Completing the chassis and car is next.
Thank you very kindly.
Thanks for this, Ken. This is metalworking at a very high level of skill. Although you describe it modestly, I know from my own efforts how easy it is to end up with out-of-line holes which I then 'bodge' into line by making them oval! I'm always reluctant to invest in the right tools, too - I guess there's a lesson there.......
Mike
· Jim Moyes
Really interesting KRZ! Thanks for sharing.
Just a thought - would starting with 3/4" x 1-1/2" box not save a lot of the waste in your last pic? If such a thing is available.
Or do you have a good source of the 3/4" that you use?
Thank you very kindly Kevan, Mike, and Mr.M.
A man can't have too many good, quality slot car tools in his shop. It's against "slot car" laws... somewhere.. I'm sure.
Mr.M. This material is very cheap from Home Depot. It takes about $3 of aluminum to make one car. Being square makes the material a bit stronger in the vise. I plan to take all the cut-offs to a scrap metal buyer soon to buy... a coffee maybe?
These out-corner many RTR cars because the CG is really low. The entire chassis weighs 7-grams. The upright bearing supports weigh almost zero. Installing 10-grams of lead to the bottom makes the bulk of weight 1mm off the track.
Discussion Starter · #18 ·
I forgot to add.
For NSR or Slot It univeral guides with screw = #27 drill bit.
For Mr Slotcar univeral guide with screw = #25 drill bit.
Hi Matthew77. I documented and built this chassis last night in real time. I will be happy to show everyone the car when it's completed. There's a big mess to clean up in the shop at the moment. Who did that??
All my builds so far have been on file. The tutorial required a fresh build for the sake of pausing for photos during each step.
I hope to race this car this coming Tuesday night in slow Sports Car class. It won't take long to finish.
Discussion Starter · #19 ·
A little bit of progress.
Tire Wheel Automotive tire Motor vehicle Toy
Wheel Land vehicle Vehicle Tire Car
Wheel Aston martin db5 Tire Land vehicle Car
Tire Wheel Vehicle Car Toy
Tire Wheel Vehicle Car Hood
Wheel Tire Vehicle Car Hood
Tire Wheel Vehicle Car Motor vehicle
Gadget Gas Automotive exterior Electric blue Auto part
More to follow. Thank you very kindly for looking.
1 - 20 of 103 Posts
