So, I've been working on this again after a break.....
I managed to make one of those really annoying errors that make you want to throw the whole thing away and never work on it again!
Having originally thought ot use the Beardog 030 motor I then realised that that just wasn't going to move this car quick enough so decided on the slim line motor type but somehow (probably drunk) managed to measure it 5mm too short and then found it wouldn't fit. Duuhh. I've resoleved that now by modifying the chassis enough...
So let me just say a few words about the inspiration for this build. I'm currntly into the '70's F1 thing as I think it is a very interesting period in the evolution of motor racing. The cars really changed dramatically over a very short time and every car was completely different from the next. I love that as it makes for interesting grids with some types working on some tracks and vice-versa - for slot cars too.
Having made a space frame car (Vanwall) and completed that kit-bash of the Surtees I really wanted to make up the P34 kit but on receiving the kit and realising that it contained a model of the whole interior chassis detail (unlike the earlier Surtees) I couldn't resist to try to model it.
Of course being me I wanted to make a REAL monocoque such that it was self supporting, not just a sham. AND it needed to be metal but it took quite a long time to realise that instead of fixing together seperate thin sheets of metal I needed to develop the origami idea into a single piece of metal folded up.
I used 0.2mm thick sheet which in hindsight is much thicker than it needs to be. If I were to do it again (which I wont) I'd use 0.1mm as a start since once folded up it is extremely rigid.
Now the chassis is done the first thing I started is the 4 wheel steering. Obviously the most fascinating thing about this car IS the 4 wheel steering so I HAD to build that. On the Vanwall the steering was the last thing I tackled and the least convincing (it worked of course but looked a bit rubbish). So here I decided to start with this. Also because if I failed then I wouldn't waste time on the rest of the build first.....
I started by fabricating the stub axles witha pivot link point inboard and a screw thread outboard so the wheels can be screwed on.
The kit wheels were drilled out and a brass bush added to rotate on the axles.
Trial assembled last night in different positions you can see that the front and back axles have already been linked together to work in tandem. All that's missing now is the link to the guide.
The A frames are wider apart than the stub axle pivot tube so that the stub axles will all be able to travel up and down a little to take up any road imperfections.
So far so good.....
Andi
