QUOTE (300SLR @ 19 Jul 2012, 08:27)
<{POST_SNAPBACK}>Conflicting ideas there!
Many cars work better with a lower c of g, maybe you'd expect moving weigh to the inside would be best for them.
Cars that are very short of grip are sometimes improved by a higher c of g, maybe you'd expect moving weigh to the outside would be best for them.
When cornering, moving weight naturally goes to the outside.
Moving weight to the inside is more difficult. Much the same effect as transferring weight to the inside can be produced by gyroscopic action (as in Gary Fletcher's car). The gyroscopic actions works instantly when the car starts cornering. Weight that takes time to move across the chassis would make much less difference when at the entry to a corner.
I guess it depends on what the limiting factor of the chassis is without the moveable weight. If the car is tipping over, then weight on the inside will help whereas if it's sliding then weight on the outside 'could' help if the chassis flex is balanced suitably like a 1:1 go kart.
I hope some of us try these ideas out - great stuff!
