1 - 5 of 5 Posts
Hi all ,
as per cleaning tips found on this web site
http://www.hoslotcarracing.com/
i used ATF oil to clean the rail but i might have used a bit too much and now thew track is all slicky with the oil.
I tried cleaning it up with wsome windex but that di not work ..
any good advice to clean the track properly to remove that slicky film
Alain
Thats going to be a long job now, dry paper towels to remove the most of it, and then some form of spirit to dampen a cloth to remove the rest I guess !
Probably the best thing to try is water and detergent, you'll get a horrible mixture of emulsified oil and water initially but keep at it and it will get rid of it. I wouldn't use washing up liquid as it has a high salt content, something like car shampoo would be better.
Rich Dumas
I avoid using water based cleaners on my track, it can get into the connections and cause rust. I clean my track with lighter fluid (naphtha) and that should remove the Dextron without damaging the track.
QUOTE (RichD @ 17 Jan 2012, 12:41) <{POST_SNAPBACK}>I avoid using water based cleaners on my track, it can get into the connections and cause rust. I clean my track with lighter fluid (naphtha) and that should remove the Dextron without damaging the track.
Super
Thank you
1 - 5 of 5 Posts
