A useful shortcut when choosing sidewinder gear ratios:
If you have a sidewinder set up with a fixed motor shaft to axle distance, are using standard pitch gears and want to change ratios, any combination of pinion and spur with the same total number of teeth will work e.g. 14:45 > 12:47 > 18:41 etc.
I don't know if this will work with the compromise pitch/diameter gears used by Slot It and other RTR manufacturers.
EM
EM
