1 - 3 of 3 Posts
WRP World Champ 2015/2016
Is it possible to leave the sensors powered up, but no power to the rails with my APB? There would be no power to the rails, only the data connections.
I'm trying to run tests with my club cars using my newly acquired true speed PWM, the problem I suddenly realised is I have no timing. Bit of a problem when trying comparative lap times.
I don't see why not. If you've already switched the power from the APB to the rails so that you can use an analog controller setup, just mod your switch(es) so that the APB gets power and the sensors are connected, but keep the power from the APB to the rails disconnected/switched. If you have the latest firmware, make sure you put the APB in analog mode, otherwise it won't see any cars (no ID emitters).
1 - 3 of 3 Posts
