I was just doing a bit of surfing and discovered these rules for a major slot car event happening across America. Note the minimum weight rule:-
Rules for "Race Across America"
Now this is something I mentioned in my Lotus 7 event thread elsewhere. We are all so fussed about loosing weight (some of us more than others!
) that it has to make things a lot easier if you have a minimum weight rule similar to that set out above.
You basically can do anything with a car with a standard engine as long as the weight of the car is not below a certain value.
That to me makes for very simple rules.
So my rules for any race event would be something like the following:-
For a Scalextric NASCAR event
You can use any Scalextric NASCAR chassis and standard Scalextric 18000 rpm motor.
The chassis must not be cut in any way, shape or form.
The body must not be cut in any way, shape or form. The body includes window glazing and spoilers.
You can do anything else you like to the car but it must weigh a minimum of 90 grams
No magnet downforce permitted.
Thats it!
These must be the easiest rules in the world to understand.
How can anybody be accused of fiddling or cheating with rules this straightforward.
A minimum weight, standard body, chassis and standard engine ruling makes things ever so simple
Moped
Thats it!
Moped
