1 - 20 of 26 Posts
I am using Ninco; in January I will build a moving table suspended from the wall of my garage; it will be 5,5 x 2 metres; I am using Tracker to made various layouts but I am yet uncertain on two or four lanes.
I will show to you the work in progress.
Ciao
Graham Windle
I have always had routed until my shed roof gave way about 18months ago ,ruining all my hard work I replaced this ( along with the roof ) with about 60ft of Polistil track with the steel rails coated with copper tape .The result is super smooth with perfect continuety and magnatraction .The down side is the rails are slightly raised so the cars I run at preston and pendle are a bit low but its still good for testing .I have 3 of the cheap carrera sets and I will be replacing it soon but I also have plans to rebuild the routed track when time allows.
Graham
Currently a mix of Classic and sport (mostly classic) Scalextric. Which i find works great. unfortunatly this is not a permanant setup
due to a Lack of space
and time). When the she that must be obeyed and i move to a larger house in the summer (i currently live in Teesside work in Wilmslow 170 miles) and am home for longer than the weekend all my slot projects including a 3 lane routed track will move on in earnest.
I would be interested to know why people run the tracks they do.
I run a combination of classic and sport track as i have been collecting slots for almost 20 years and to replace all the classic track with sport track would be very expensive. I got the John cooper challenge set as a Christmas present so i could finnaly upgrade my controls and join the brakers. I have to say having the abilty to brake the car makes racing much more fun and controlled.
Wayneslot
wayneslot,
I run Carrera track because I have enough space for a large permanent layout. I also like the deep slot and smooth surface. Carrera's width allows me to run 1/24 cars, which I do quite often. Also Carrera rails will not rust and are less magnetic so today's magnet cars do not feel as stuck down.
TR6er
Ninco for me. I like the lane spacing and the ease of set-up. I don't have the space for a permanent layout and I can get the Ninco set up real quick. Holds together great on carpet and really sturdy if someone mis-steps
I currently run on scaley classic in 4 or 2-lane configuration depending on conditions. I run it because I've collected the pieces for some time now and I can't afford buying a new system. I run no mags, and no breaks ( I have modified one controller to take brakes but I can't be botherd doing it to three more). I've made my own borders from different types of wood, and masonite. here are some pics:
Suzuka:
I've just got a router so I'll be making something new when I'll get the money to buy some sheets and tape. Here's my first routed track that I built when I was in Melbourne last year:
more here
There's nothing like the smoothness of a routed track
Toby
Recently I increased my home "circuit" by some 300% or so (maths not my strong point).
Yeah, now I have three C160 Scaley straights linked up to a dragster turn!
Hut ya!
Keep getting outbid on the necessary extra dragster turn. Boo.
I look at you guys with your basements, and your lofts, and your garages, and your big layouts with closed loops like a little Dickensian orphan, face pushed up against the toyshop window in awe.
Sniff, sniff.
Wankel, I hope you're not fishing for sympathy?
Anyway, didn't you buy at least one Slot Forum 2003 Commerorative Carrera Set for £30 at Argos Special Edition?
As to the topic of the thread I can't vote as I have , I have mostly classic with some SCX and Sport (split about 50/25/25 for the detail fanatics among you).
Scott
Scalextric digital was the way to go because simply of availability and also because it allowed me to fitt a bit of lenght onto my permanent layout (~45m). Using a track designer (Ultimate Racer 3.0) you can play around and see what you will get. With the excellent PB-Pro 1.8 SH plenty of ower is available for any number of cars. Using SSD Console by Any Wallace you can see all your mods and results on a screen, you can record and playback your pace cars (in case you are a "lonely" racer - as I am). The soon to be released upgrade will even playback lanechanges. Endless possibilities on the horizon.........
happy racing
Albert
1 - 20 of 26 Posts
