1 - 4 of 4 Posts
Hello everyone,
i`m on the verge of investing in a scp01d controller. Can anyone tell me which scaley psu model will do the job? looking on ebay there seem to be many different model numbers available (some very cheap) and varying voltages. Also I guess the plug size has to be correct,
any info very much appreciated,
Dave
I use C7004 but C7042 will do the job too. Obviously, cheaper option is C7004.
Either Scalextric PSU will work with the provided power adapters. I'm not sure if the APB-compatible version has all the same connectors as the other one, though. It might only come with the C7024 and SCX power connectors, since that's what it's sold as being compatible with.
Either way, you can use the connector for the SCP from the power connector you won't be using (SCX) and wire it to a battery pack of your own making quite easily. I tested a simple 9v alkaline battery ages ago and it worked great.
1 - 4 of 4 Posts
