1 - 9 of 9 Posts
Font Line Parallel Rectangle Pattern
Hi all im fairly new to slot cars although ive spent a fair time reading about it on here, anyway i hope my track plan is attached to this if not you can view it in my gallery not a pc expert sory ! Iwould appreciate any comments any of you may have about my track thanks
Wow !!!
You must have a bit of cash to flash with that many lane changers.
Why so many ?
Are you just drawing-in all possible positions...
...from which to decide on the final selected positions ?
Si.
I assume your using Sport track or is that Ninco ?
I love your double-apex chicane type complex at the centre of the 'L'.
That should be a blast to drive.
They really sort the men from the boys !
More time won or lost in those sections, than on the straights; just like the 1:1
Si.
While no expert on track design the problem with this track may be visibility. However you look at it the pit is going to obscure 2 straits whichever side you view it viewing from a short side is not really practical.
· Greg Gaub
Trust me, you don't need so many lane changers. One at the end of each long straight is plenty. The one in the middle of that long striaght will be useless. Since most can't be taken at full speed, putting them where you're already slowing down is best.
Line Font Parallel Slope Rectangle
Thank you for help ive amended plan by moving pits etc to rear it dos give clearer viewing and has i think made the whole track more interesting. Ive also decided on lane changers was undecided before where to put them so put in alot trying to decide !!! would appreciate any comments anyone has on new design thanks again
Hi Wookie
You could have triggering probs. with the 'X' changer after the pits.
You would do better to move it along a bit.
Why follow this imediatly, with a curve changer ?
You could just use 1 here.
The 'X' changer on the 2nd from bottom track, parallel to the pit-entry, may have the same trigger issues.
You could move it along a bit.
Personaly I favour more 'C' changers, than 'X' ones, but choosing which direction one to buy then becomes an issue.
Outside-to-in, L or R, would be my answer to that, but depends a bit on the track-map
Si.
1 - 9 of 9 Posts
