QUOTE (1wvslot @ 6 Nov 2009, 08:23)
<{POST_SNAPBACK}>1. Which track is the better track as far as compatability to other tracks?
None of the digital tracks are directly compatible with each other, but some can be adapted, and most have an analog counterpart that will work with it. For example:
Scalextric Sport (analog) track and Scalextric Sport Digital are 100% compatible.
Scalextric Classic can be connected to Sport (and Sport Digital) using an adapter track.
Ninco Analog and digital track are the same in the same way.
Carrera Analog and digital track are also the same in the same way.
SCX Analog and SCX Digital Track are NOT COMPATIBLE AT ALL with each other.
For the most part, you can't connect different manufacturers together with a couple exceptions. SCX analog and Scalextric Classic are pretty much the same, so a Classic-Sport adapter is all you need. I believe there are also Ninco-Scalextric Classic adapters available.
I don't think Carrera can be adapted to other makers, but I could be wrong.
Compatability with other makers is something to consider, but not as important as overall quality and surface type. If you've never played with any of them, it would be a good idea to check them out at a local hobby store and see which you like best.
<{POST_SNAPBACK}>2. Can any manufacture's slot car be run on any track?
Only with analog. With digital, all the makers did it differently, and so they are NOT compatible with each other.
<{POST_SNAPBACK}>3. Can any brand Digital Board fit into any manufactures car?
Example, Scalextric boards in Carrerra Cars or the other way around.
To a certain extent, yes. Some are more challenging to install than others, such as the SCX Digital chip, which includes a complicated system for the guide blade. The others, more or less, only need you to find room for the electronic board itself, and maybe a sensor or LED.
<{POST_SNAPBACK}>4. Will Analog cars run on Digital tracks?
No. Some people mod their tracks to have an analog ability, but I don't think any maker yet has a system with an analog mode. If you put an analog car on a digital track, depending on the track, it can do anything from make a funny noise to shoot off at full speed. The unreleased Scalextric 6 car Powerbase is said to have an analog mode, and an upgraded 6 car PB to PB-Pro also has an analog mode. I don't know if any other makers have this feature, but I don't think so.
<{POST_SNAPBACK}>5. Also, If I buy Carrera Digital cars, Will they run on Scalextric track. Or any manufacture's car on another manufacture's track.
No. Not digital, anyway. They're all done differently, and therefore will not work on each other's tracks. Like with an analog car, it might just sit there, or it might shoot off. It's also possible that the chip could be damaged, but I have not heard about this happening yet.
<{POST_SNAPBACK}>I was looking at Scalextric's "American Champions" set and want to convert the track and cars to Digital.
Will this work? I also was want to purchase a couple of Carrera cars.
Sure. You can do that with a digital upgrade kit, or just get a digital kit and combine the track. All Scalextric sets sold any more use Sport track, which is directly compatible with Scalextric Digital track. Then you just need to chip the cars. Depending on the cars, that can be a simple drop-in chip called the DPR chip, or you might need to solder a couple wires using the retrofit chip.
Chipping Carrera cars is usually pretty easy. I've got 4 chipped Carrera cars on my track now. Just make sure you get an analog car, and not a digital one, as you'll be wasting money on a chip you'll just have to remove to replace with the Scalextric Digital chip.
Hope that helps!
-Greg
