Cheap 12v Power Sources for PB1.2 SSD
1 reading
808 views 4 replies 4 participants last post by  MrFlippant
#1 ·
I have the 6 unit 1.2PB and the c7004 is hard to get hold of. I have been looking around the house for compatible 12v charger to use in the second power slot of the PB1.2. I found two candidates. one is the power supply from a high capacity energizer recharger which is 2.5a 12v; (link below). Perhaps a bit underpowered? The second is a dedicated power supply for a muchmore/schumacher style radio control charger rated at 12v 10a. Its currently got 4mm bannana connectors so I'd have to make a lead up. I cannot find the exact model but its similar to those linked in the bottom 3x
However is there any reason these should not to tried? Also which input do I plug into?
Appreciate your advice!
Links
http://www.amazon.co.uk/Energizer-Battery-...r/dp/B000QW3VO4 [2.5amp]
http://www3.towerhobbies.com/cgi-bin/wti00...LXRJN7&P=WR [10amp]
http://www3.omnimodels.com/cgi-bin/woi0001...NTP2052&P=0 [10amp]
http://www3.omnimodels.com/cgi-bin/woi0001...MRP1055&P=0 [7 amp]
#2 · (Edited by Moderator)
I would not use the 2.5 Amp unit or plug it up with the C7004. it's never a good idea to mix PSU's.
I would say the 10 Amp unit is the best bet. I would be happier if I could find a full spec, but as it's switched mode I assume it's regulated? If you have a multimeter put it across the terminals and check that the off load voltage is 12 to 13 Volts.
You will need to make up a cable so that the single supply is plugged into both P1 & P2. The Powerbase detects this and increases the current that can be drawn.
However remember the 1.2 has a relatively frail output stage, which is easily damaged. Having a greater current available does not necessarily make things worse, as a hard short without a volt drop on the PSU will cause the Powerbase to overload quickly. However a partial short with more amps available can cause the mosfets to cook. That said you are probably in no more danger than with 2 x C7004.
Remember if the worst does happen, or even if not, you can always upgrade a 1.2 Powerbase to PB-Pro + S-H Power, which replaces the output stage with one that is virtually indestructable.
Rich
#3 ·
If you were to update your profile, I'd know whether or not to offer you a C7004 power supply so you could have two. But from the looks of the links you provided, I'm guessing you are not in the U.S. and it would not work.
#4 ·
Sorry, I am new this week, havent had a chance. Sadly not in the US rather rainy UK. Check out my new circuit uploads in the track section today as a powerpoint file. Appreciate the kind offer....seems I am set to blow something up instead
#5 · (Edited by Moderator)
Stressor, IMHO, you're best off budgeting for the PB-Pro and Simple-H (S-H) mods and never having to worry about it again. Well, that and a good regulated Power supply. I've done my research, and put in my down payment for the upgrades just yesterday. I can't wait to run 6 cars (with friends, or with pacers
PS. YAY! I'm not a tea boy any more. I've got my learner's permit.
