How to fix AW flamethrower shoe spring tension issue?
3 reading
1.8K views 9 replies 5 participants last post by  c-vroom
#1 ·
Is there a known (easy) fix to get the Auto World Flamethrower cars running without deslotting?
I just bought an Auto World '56 Chevy Nomad Flamethrower (xtraction), and noticed that the spring tension from the flamethrower modifications lifts the front wheel off the track to the point there it delots going around corners too easily.
Searching around this seems to be a standard design issue. Does the community know of a simple fix for this?
  • "Slot Valley Racing" mentioned in the comments section of this video that he aded a metal guide pin to fix it.
    • Does anyone know where I could buy something like that that would fit the flamethrower's xtraction frame?
  • I've seen people bend a curve into the shoes to limit their travel (for slot cars in general). Maybe that would work?
#2 · (Edited)
Oh, I got it working pretty well by just bending the copper bar under the silver plate that holds the shoe spring. The copper bar still forces the shoe to ride a little higher then it's normal low position, but at least it's drivable now.
I think a better permanent solution would be to remove the copper bar, and solder a stiff jumper wire wrapping around the side of the body instead.
I'm kind of surprised they went with a dim incandescent bulb rather then a brighter LED. Maybe to make them look more like older headlights?
Pictures
Normal configuration
Modified configuration
#3 · (Edited)
Dear Lord,
Some badorkmore who failed 5th grade science and knows less than nutten' about pancake shoe tuning dreamed up that cludged mess. All they left out is a chunk of 2x4, a drywall screw, and a clothesline rope for steering. Sadly they left the wires waaaaay short to return it to the original AFX configuration/design easily.
1. Best bet is to drill out and toss all their junk, then replace the grain of wheat bulb to get the longer leads required. Tin and flatten the new longer lead ends by bopping them, and sneak them under the hanger plate. The quikee.
2. You could also extend the existing leads, toss all their junk; and combooberate things the right way. Ya gotta be good, in order to keep it tidy. not my first choice, but I cite the option.
3. One might trim one end of the shunt to re-use it with new longer leads, then bend the remaining end over the corner of the chassis like an "AFX magna flamethrower hanger plate" and jiggle the shunt under the hanger plate.
You have options. Any combination of the above would serve, I reckon. You get to decide! The only really critical requirement is getting their junk out of the shoe's travel zone, and restoring the tension to normal.
Good Luck
Bill
#7 · (Edited)
Well CB, I'm older than dirt, but I can still remember the before times. Retaining the leaf spring/design, and tossing it cockeyed in the shoe travel, automatically makes the Xtraction a Lame-thrower. Similar to the shoe adjustability of the ancient by guess and by golly, like Tyco S or a Pennline.
It's wonderful to hear they are aware, and hopefully proactive. If you're gonna copy something, copy it right, rather than going alacarte' and halfassing the details.
The coil springs can be elusive/annoying lil buggers at times, but the all important spring rate is dialed in within reason; where as a sliver of scrap phosphor bronze would be more at home on a neolithic cart.
Tuning capability and reasonably consistent spring rates for lever style hard shoes was a big jump ... in the last millennium. Otto Whirled re-inventing the Ox drawn cart with a light bulb in this millennium, maybe not so much.
#9 · (Edited)
Har!
Yes sir, "wunner wot dese nubs is fer?" There's a always been a fundamental disconnect at Otto Whirled. It's always sumting utterly basic that's amiss.
If you throw enough straight parts and time at them, there might be a slot car in there.
I see you found their secret plans for inculding the drogue sail/rear guide pin. See square rigger sailing techniques after 1492 or there abouts.
