Looking for opinions on my Carrera track and how to possibly improve it
4.2K views 17 replies 10 participants last post by  kalgani
#1 · (Edited)
Looking for opinions on my fairly basic Carrera track and how to possibly improve it. I have had it setup this way for several months now. The track length is just over 40 feet long (both lanes). It does hang over my 18 foot table a little bit on both ends, (specifically the shoulders hang off the ends). The table is 18 ft x 5 ft.
Thoughts? Suggestions?
#3 · (Edited)
First off it looks very nice! Your layout reminds of my second (even with it being twice as long) although it's much better done than mine. Obviously you know more what you are looking for than someone else however I'd lean towards two changes... making the turn at the end of the long straightway more sweeping (use the entire table's width), sacrifice most the shorter straight and replace it with various radius curves. Perhaps creating two overpasses or one longer one which should allow for some nice esses and or chicanes. That would increase your turns' variety and add some uniqueness to the various sectors.
#4 ·
I did not know that the space station had room for a slotcar track. I bet those magnets are helpful in no gravity settings ;-)
Joking aside, I think Mr Flippant's comment is something I was pondering myself: it seems that you have enough space to make the table wider.
I like the Bertrand fo8, but I find it boring after a while. Having 4 different "depths" (compared to only 2 with the fo8) I think it is more interesting.
#6 ·
the end closest to us could be made into a larger radius curve with various sections ie r1,r2,r3,r4,r4 or reverse order so as the right hand straight came along the right hand edge of the table ,that would add length but also give this end curve a bit of variety and speed with a challenge .that would be my first change , after that more width in table ,up to 2100mm wide ( 7ft ) would give you a heep more options
#9 ·
In my opinion (biased and unrealistic - I am more determined than I should be to fit small interesting layouts into spaces using Carrera!) you should be able to get a reasonable amount of variety in a 5' width. Its about as narrow as you can work with in Carrera. I'll keep this in mind for the next few days as I saw something on social media recently that might fit, will see if it pops up again.
#12 ·
wonder if @kalgani has any ideas? In the mean time another Bertrand variant with bigger loop, not unlike what has already been mentioned but thought I’d post it anyway. Don’t bother unless you already have the bits lying around as it’s a similar flavour of what you already have.
#14 · (Edited)
My current layout has a moderately banked R2 turn (180 degree turn) at about 7 degrees banking, as I didn’t want my lower cars bottoming out on a full R2 bank. I just propped it up, it allows faster corner speed and I just used flat track sections. Not an ideal engineering solution in theory but it worked for me, don’t really have any issues.
Also, have a look at post #61 on this page: Carrera track ideas
Apologies for lack of direct image and link formatting, I've clicked something bad and have lost the option to do both.
#16 ·
that is a good idea ,shift the single lane change you have at the end of the right hand straight and put it just before the pit lane ,so someone can change lanes and then enter the pit at the last moment if you are using fuel sometimes people forget and find themselves in the wrong lane ,then put in a double where you took out the single ,mainly for lane changing ,but if you were to make that bend a larger radius turn then the lane changer would defeat the purpose ,cos you would need to slow down for the lane change when more speed could have been used in the big bend,
so you need to think about what you intend to do for layout first as it sounds like you want to go bigger . get a layout you like to drive first and then when happy ,start putting in lane changes ,some people say lots ,but less sometimes make for more tactics ,
#17 · (Edited)
I put some more tracks on the table...
Fast opening corners, narrowing corners, slow tech parts and fast S.
Viewability should be ok, if you are standing 3ft away from the table.
The borders in the middle right are a bit tricky but with some 8mm wood
you can build there some induvidual borders for this part.
Hope you will give it a try.
Edit:
it's ~21m / 68ft both lanes.
