Repairing crack in resin body
3.9K views 20 replies 11 participants last post by  Trisha
#1 ·
I would appreciate some advice on how to repair a crack that has occurred in a weak area on the front upper wing of the resin body I am working on (see photo). I have tried both Araldite and superglue, but neither bonded well and the crack still opened up!
I have given the body a base coat of silver spray just to highlight the areas that still need work.
#2 ·
Isopon P.38. This stuff's excellent, for repair, filling pinholes, rebuilding missing bits, reinforcing mounting posts, adding on to or reprofiling resin shells. It sticks, it's strong, easy to roughly cut to shape when just gone hard, and will file and sand to a fine finish once fully set -
To repair your crack, roughen up and clean the shell on the inside around and over the crack, then layer it up with a good dollop of P.38 (be generous). When the inside's set, if you need to work the crack on the outside, cut the crack open a bit and fill it with P.38 again, and finish.
#4 ·
Whenever I sand or saw resin bodies I collect the dust and use it with superglue as an extremely strong filler and bonder. I add superglue to the area that needs to be filled or bonded and then sprinkle the resin dust onto the glue. It ends up as strong if not stronger than the original resin and can be cut or filed.
#16 ·
I completely stopped using superglue a long time ago. I couldn't unscrew the top from a tube with my fingers, so used my teeth instead. What could possibly go wrong? Yep, I discharged the whole lot into my mouth, and had to spend a couple of hours trying to get rid of it.
This is purely and simply because I'm an idiot, of course.
#21 ·
A brilliant idea for a thread, Daniel. What could possibly go wrong? Hmm... the short answer to the question is '"everything."
With slot car building, I am convinced that anything that can go wrong always will go wrong, but why? Why do we make mistakes? Has anyone built a perfectly flawless slot car without making mistakes? Or is Dr Sodt always lurking in the background, ready to trip us up?
