Slot.it News - Controllers and Parts
1 reading
6.2K views 3 replies 4 participants last post by  Mr. Olufsen
#1 · (Edited by Moderator)
News from Slot.it regarding controllers and tools;
SCP201d - SCP-2 Universal digital controller
Product Code: SCP201d
Description: SCP-2 universal digital controller
New Product
- Slot.it SCP-2 controller with universal digital cartridge.
- This controller is compatible with digital systems made by Carrera, Scalextric, Ninco and SCX.
SCP201f - SCP-2 Electronic controller without cartridge
Product Code: SCP201f
Description: SCP-2 Electronic Controller without cartridge
New Product
SCP-2 features:
- full compatibility with existing cartridges
- rapid mapping (slow / normal / fast) with a 3 position switch selector
- 1 or 2 fingers lever
- rubber injected finger touch
- high precision ball bearing spindle
- optional wireless operation (requires oXigen and CRI cartridges)
- optional battery operation via digital port (USB type)
- excellent progressive power delivery
- improved mapping of the brake function
- very fast turn-on time
SCP201fg - SCP-2 Analog controller, high current, common ground
Product Code: SCP201gf
Description: SCP-2 analog controller, common ground high current cartridge
New Product
- Slot.it SCP-2 analog controller with common ground high current cartridge (available separately as SCP201g), that can be used for metal slot racing as well.
SCP201h - SCP-2 Electronic controller, Oxigen cartridge
Product Code: SCP201h
Description: SCP-2 electronic controller, oXigen cartridge
New Product
- Slot.it SCP-2 controller with oXigen digital cartridge.
- Optional battery operation with oXigen battery holder (O205a - 9V) or (O205b - 7.2V 2x14500 Li-ion).
SCP201i - SCP-2 Analog controller homeset version (common positive, negative wiring)
Product Code: SCP201i
Description: SCP-2 analog controller homeset version
New Product
- Slot.it SCP-2 controller with analog homeset cartridge (Hornby / Ninco).
- Not compatible with Hornby C988 transformer.
- Not compatible with unregulated power supplies.
- We suggest using a regulated power supply with at least 2A per lane.
SCP201m - SCP-2 Eletronic Controller, Oxigen Cartridge, Telemetry Box
Product Code: SCP201m
Description: SCP-2 electronic controller, oXigen cartridge, Live Timing box
New Product
Slot.it SCP-2 controller with oXigen digital cartridge and Live Timing box.
- The Live Timing box speaks out each lap time to the racer, in real time,
and saves racing data to memory (requires headphones).
- No external hardware necessary for the Live Timing function when used with oXigen system.
SP31b - Professional mini puller rev.2
Product code: SP31b
Description: professional mini puller rev.2
Replaces SP31
Changing pinion: the nightmare of every slot racer! ...until today.
Indeed, the new Mini Puller Slot.it 'SP31b' allows to remove and adjust* the pinion position without waste of time and hard work to unmount transmission and remove motor from chassis.
Allows the replacement of all pinions up to a diameter of 6.75mm
The Mini Puller may be used with either anglewinder and sidewinder motor mount types.
* The Mini Puller can only 'pull' the pinion. To press it on, the Mini Press is required.
Images and text as supplied by Slot.it
#3 ·
We've had the 'Telemetry box' for a while.
Actually, we call it 'Live Timing' now, because its prominent feature is live timing playback in your earphone: lap after lap it tells you your lap time. Besides, it saves all your lap times in memory. Programmable in many languages, with malle and female voices, mixes with MP3 music player input as well, dimming the music when lap time is played back.
The 'Live Timing ' playback and lap timing memorization function do NOT require a Slot.it controller. Telemetry (save trigger and knobs position, saves and compares lap times, etc...) functions need a SCP controller, instead.
oXigen digital is natively compatible with all these features - what you see is the special bundle SCP-2 + oXigen cartridge + Live Timing / Telemetry box.
#4 ·
I just received the SP31 mini puller and the SP30 upgrade kit (mini press). Two very neat tools in the usual high quality I have come to expect from Slot.it. I've been playing with them a little, and they work as expected. They are really going to save me quite a bit of trouble in the future.
Christian
