Isn't needle point some form of poncy embroidering or other such girly activity?
QUOTE (Screwneck @ 24 May 2007, 13:47)
<{POST_SNAPBACK}>Use a pin after dipping it in oil.
It may sound crude, compared with an allegedly purpose built hypo oil bottle, but I almost completely agree with Screwneck.
Pinpoint oilers sound good and are most certainly better than nothing. But my personal experience is that there are some downsides. It's way too easy to produce a massive great drop, that is far bigger than needed - it can be messy. In addition, I haven't yet found one that would retain its contents, reliably, during temperature changes and not being kept upright at all times. They always seem to end up messy and manage to spread oil on most everything else after a period in a tool box or whatever. Better pinpoint oilers may exist, but I haven't found one yet that beats the real pin and oil. I suspect one pays well over the odds for these things in any case.
I haven't bothered, but a short length of micro tube might be slightly more effective than a simple pin, in that capillary attraction will produce a small reservoir of oil that will last a little longer and enable lubrication of several points per session. The downside is that you still have a drippy tube when you've finished.
That's why I haven't bothered!
But, imho, best of all in its simplicity and effectiveness, is the crudest of all - a tiny, torn off scrap of softish paper (or fine cloth) torn with a sharp angle at one corner. About the size of a finger nail. You can use it flatish, but it's better if curved and best of all if rolled into a cone. With experience, you will very swiftly arrive at the style, shape and size that suits YOU. Newsprint is perfect, glossy magazines not so good. Toilet paper or kitchen tissues are also great. The cost is nothing and you can produce one almost any time, anywhere. Keep your bulk oil in a reliably sealed container that won't leak in normal circumstances. This way, the oil is cheaper, there is more choice of product, and its application is more controllable than any hypo type oiler I have seen. Just dump the scrap of paper after use, or take it to a recycler if you really care that much!
Bear in mind that a so-called pinpoint oiler is only trying to emulate what one does with a pin and oil anyway! (and charge you for the privilege). As always, it's your money and your choice, but the little corner of paper is a real winner in my book.
The spin-off advantage of paper or cloth is that, should you manage to over oil, you use another little scrap to soak it back up. It's a sure fire winner in the oiling stakes but carries no hi-tec kudos. Who cares about that - it works really well, the very best imho.
